Author Topic: Random parameter problem  (Read 8806 times)
MH4288
« on: May 07, 2014, 01:02:34 pm »
I tried Random node for the first time and it didnt work. Maybe I done something wrong, but when I used Numeric node, it was ok.
Really easy setup. Object in Corner and Evenly try to random rotate on Z. Export Rand.Rotation 2 Z, turn on Random rotation in properties, attach Numeric node and change value in Properies folder, everything is ok.
But when I attach Random node, nothing happened. And I dont get the "Generate on" property.
Re: Random parameter problem
« Reply #1 on: May 07, 2014, 01:44:42 pm »
This is probably linked to the evaluation order of the nodes. Certain expressions don't work when linked directly to a segment node. When this is the case you can use a transform node to bypass these restrictions.
Hope that helps,
kind regards,
MH4288
« Reply #2 on: May 07, 2014, 06:02:28 pm »
Oh, ok, thanks.
Maybe would be good to disable this connects, so user cant link two nodes which cant work.
« Reply #3 on: May 07, 2014, 07:59:15 pm »
Yes, it should show a warning message, in the same way when connecting an Arithmetic->Expression.
We forget to do it when Random was implemented. We'll fix it.
