Author Topic: The brick wall itoo video on youtube...  (Read 90860 times)
TL1895
« on: May 29, 2013, 04:05:49 pm »
...Looks great, but how does one achieve this or similar result?  Was that a custom style made for that video?  Anyway, any more insight into the whole process would be really helpful...RC2 is great so far, much better interface IMO.
Re: The brick wall itoo video on youtube...
« Reply #1 on: May 29, 2013, 09:31:51 pm »
This scene is pretty simple: just one Array generator, a single Segment (brick), and several random transformations (Z scale and material). I attach the scene if you like it.
Tip: try changing "X Rotation" and "Slope" in the Generator to get interesting effects.
TL1895
« Reply #2 on: May 29, 2013, 10:06:15 pm »
Thanks Carlos, I am going to have a peek!  Can't wait.
TL1895
« Reply #3 on: May 29, 2013, 11:29:54 pm »
I tried the slope and X rotation, and that was cool!  Is there a quick way to make the same type of wall but the bricks are offset by 50% (sim. to brick common bond.)
« Reply #4 on: May 30, 2013, 12:33:30 pm »
Here is a sample scene using a common bond pattern.
I used a Sequence operator on Y axis, applied to the "Left Side" slot. In this way, each row starts alternating between two Segments: simple brick, and half brick+brick (created with a Compose operator).
There are simpler modes to get this pattern (you will see it in an upcoming tutorial), but this workflow allows to randomize each brick individually.
« Last Edit: May 30, 2013, 12:37:15 pm by iToo »
TL1895
« Reply #5 on: June 03, 2013, 02:18:42 pm »
Hi Carlos, thanks for uploading the sample bricks scene2.  I will look forward to the next tutorials as they are quite helpful.
