Author Topic: RC vray GPU or Vantage rendering  (Read 7657 times)
Crayox
« on: November 30, 2023, 01:57:45 pm »
Hi guys,
I have this RC parking generator that places cars and parking lines along the lines (spline). For some reason cars that are vrayproxies and render fine in normal CPU vray render, under GPU engine or in Vantage render as boxes. My other RC generators render fine (I think) under GPU. Any ideas?
Re: RC vray GPU or Vantage rendering
« Reply #1 on: December 01, 2023, 10:30:02 am »
I'm afraid this is a limitation of RC when using proxies. It's logged in our system as a bug, but has not an easy solution.
As workaround, you can set the Display mode of the proxy to "Whole mesh". That fixes it.
Crayox
« Reply #2 on: December 01, 2023, 11:20:09 am »
I see, thanks!
Crayox
« Reply #3 on: December 01, 2023, 01:17:41 pm »
Just tried to select "mesh" and nothing happens. It's a rather small parking lot so like 15 cars and I increased segments and polys to bilions so I don't think it's that. I updated vray to 6.2 so not sure but maybe it's due to that? Because I just noticed FP objects don't export to Vantage now after 6.2. Not sure if it's related.
Crayox
« Reply #4 on: December 01, 2023, 01:29:48 pm »
Also just realized I posted this in FP instead of RC. Can someone move it please if necesary?
« Reply #5 on: December 01, 2023, 03:09:14 pm »
Moved.
But you changed Display mode in RC ? That's not needed. I mean to select full Mesh mode in the preview options of the V-Ray proxy.
Crayox
« Reply #6 on: December 02, 2023, 08:50:07 am »
OMG no! Never even occured to me. Oups :)
« Reply #7 on: December 03, 2023, 09:10:29 am »
Although my test with V-Ray GPU worked well, unfortunately i cannot test Vantage at this moment, because there is a problem with our licenses.
I just wrote to ChaosGroup about that.
I will post here as soon as the problem is solved, and we can test it.
