Author Topic: rotation problem  (Read 2757 times)
atomov
rotation problem
« on: May 15, 2020, 08:50:37 am »
I'm trying to make a 2S array of cylinders and to have each one rotate randomly around pivot. What I'm getting is that when I rotate segments using transform node's random transformation from 0 to 360 segments also move randomly on X and Y. I need them to remain in place, just rotate locally. I've tried it on a linear array and it does the same, why is it doing this?
Re: rotation problem
« Reply #1 on: May 15, 2020, 10:16:56 am »
Problem is usually due bounding box for cylindric.
Try to set fixed size box to cylinders diameter but without "Scale Segment" checked then add a new transform operator with X/Y Alignment set to Pivot and Random Z rotation.
« Reply #2 on: May 15, 2020, 10:28:11 am »
Here is the file
For RC4 it is better to use fixed-size parameters+Random numeric usually set to Segment mode because Random Transforms are cumulative and can cause some unexpected behavior unless you know what are you doing :D
« Last Edit: May 15, 2020, 06:09:13 pm by Dragan »
atomov
« Reply #3 on: May 15, 2020, 01:29:15 pm »
Hvala Dragane,
This is a fantastic tip. I've noticed that when rotated 45 degrees on Z it looks like bounding box is affecting it but i didn't think of this solution. This is because of new stacking transforms in version 4? I'm sure I did this before with linear arrays but I never had this problem. Thank you very much!
« Reply #4 on: May 15, 2020, 01:45:53 pm »
Nema na cemu  :D :D
Glad to help.
