Author Topic: Roof Tile Presets Verges??  (Read 2611 times)
FC1888
« on: May 20, 2020, 12:49:19 pm »
Was using a roof tile preset just now and when I deselect the verges left and right, nothing happens. Pretty sure this used to remove the overhang (what I call verges) as I was the style but don't want the tiles over hanging like this. Did something happen during a particular update, that prevents this feature from working. I tried several styles similar to this, with his horrible overhang and no matter whether you have Verges selected or not, they remain. Really need a fix for this as I said, I am pretty sure when you deselect the verges feature these SHOULD be removed
Re: Roof Tile Presets Verges??
« Reply #1 on: May 20, 2020, 01:33:12 pm »
Thanks for reporting.
To use the styles before we fix it via update manager You can do the fix Yourself:
1. Add "1" to the boolean value using an Arithmetic operator
2. Swap the order of the segments wired to the Selector operator.
FC1888
« Reply #2 on: May 20, 2020, 02:41:38 pm »
Actually I found a faster fix for now.. Just disconnected the verges segments.. but yes, at least I was correct in that it should remove those when verges is set to off. Thanks for the prompt reply.
