Author Topic: RC object shown on other side of a spline  (Read 3243 times)
MH4288
« on: September 21, 2018, 09:20:34 am »
sometimes I have this problem, RC show on the other side of a spline. Sometimes I have multiple splines in one spline object. And on one closed spline RC object is opn the other side. How can I fix that without redrawing it? I tried reverse the spline, but no luck.
Thank you.
Re: RC object shown on other side of a spline
« Reply #1 on: September 21, 2018, 09:33:14 am »
Can You please illustrate this situation with max file ?
Piotr
« Reply #2 on: September 21, 2018, 11:17:58 am »
I had similar problems creating roof tiles with openings. As you said the first thing you have to check is if it works with reverse splines, if not then I suggest trying to set first number vertex in for example left bottom corner of a spline and similarly with internal opening splines. Please let me know if it helped you.
MH4288
« Reply #3 on: October 03, 2018, 10:05:37 am »
Ok, thank you. I will test it when problem shows up again.
