Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Segments not being sliced across edges
« previous
next »
Print
Pages: [
1
Author
Topic: Segments not being sliced across edges (Read 6394 times)
HB2523
Newbie
on:
October 09, 2017, 06:26:46 pm »
I've made a simple box and a closed spline with some Corners and Beziere corners. The Segment node with the box is set to both Bend and Slice but the slicing doesn't work propperly. It doesn't slice across the whole model but leaves edges intact that results in intersecting polygons. See the attached image. How can I fix this to get a better connections between the segments?
Logged
ITOOSOFT
Hero Member
Re: Segments not being sliced across edges
Reply #1 on:
October 10, 2017, 12:01:47 pm »
You can adjust how
Corner
s are handled under Generator's
Rules
Corner
Bevel Mode
Bevel Corner
etc. Also, the
Alignment
settings for used Segment will have influence over the final result. Hope that helps.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
