Author Topic: Material Editor Renders reset  (Read 2531 times)
Bost Digital
    • Bost Digtial
« on: May 29, 2023, 10:21:05 pm »
As the title of the post says the Material Editor resets all the rendered materials when selecting a RailCone object. I can select something else in the scene and then click back on the RC object and it makes the material editor re-render all the visible materials in the editor. Using v6.0.7 did not notice this with earlier versions.
Color management is set to 2.2 Gamma workflow if that makes any difference because as something similar was happening with Forest Pack when working in the new OCIO colour management profile.
Re: Material Editor Renders reset
« Reply #1 on: May 30, 2023, 08:46:41 am »
I'm sorry to hear, you're facing these troubles. Well, in theory, that should be already fixed (there was a problem related to the new Color Management handling in 3ds max 2024, and the fix was applied to both of our plug-ins). Please double-check, you’ve installed also the latest version of the Forest Pack plug-in.
In case of any further troubles with it, if possible, please feel free to send us your scene to check it here. Ideally, if you'll be able to reproduce it on a minimal scene, which you can send us, it would be great. Thanks in advance.
