Author Topic: Set Marker ID before placing  (Read 2688 times)
DT
« on: December 01, 2021, 05:35:47 pm »
Is it or would it be possible to set the ID of your marker already before placing it (with the refine button or what you may call it). I have to place for instance 10 markers with ID 3, there are also other markers already palced with another ID so it's not like I can select them fast. I have to select them one by one and then change the ID afterwards which is a bit counterintuitive.
Re: Set Marker ID before placing
« Reply #1 on: December 01, 2021, 06:33:01 pm »
HI,
If you activate the Copy Data to New Markers option it will use the values from the last selected marker. Hopefully that can help.
Best,
« Reply #2 on: December 01, 2021, 06:34:17 pm »
Hi.
You can stack multiple RCSpline modifiers.
« Last Edit: December 02, 2021, 08:58:41 am by Dragan »
DT
« Reply #3 on: December 02, 2021, 05:29:29 pm »
HI,
Best,
Aah yeah, jesus I can't believe I keep missing these things. Sorry for this.
