Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Expression quastion
« previous
next »
Print
Pages: [
1
2
Author
Topic: Expression quastion (Read 11309 times)
Mishanin
Newbie
Expression quastion
on:
December 03, 2019, 08:20:29 am »
Why this expression doesn't work in evenly distance or evenly count?
return if (XSplineMatID==1,3,8); - (evenly count)
return if (XSplineMatID==1,150,450); - (evenly distance)
How i can get distance between two corner?
Last Edit: December 14, 2019, 12:58:55 pm by Mishanin
Logged
Hero Member
Re: MatID expression
Reply #1 on:
December 03, 2019, 10:27:01 am »
Evenly is special distance. It is calculated once and applied throughout the spline at regular intervals.
Hopefully
this technique
can be a workaround in Your case.
Hope this helps.
Logged
Mishanin
Newbie
Reply #2 on:
December 06, 2019, 09:23:19 am »
I decided not to create a new theme
Can you explain why it works like this?
I compare the length of the segment with the length of the next segment, but in one segment it does not work correctly.
I suspect that it has something to do with the first vertex spline, but how to solve it i don't know
Logged
Hero Member
Reply #3 on:
December 06, 2019, 01:30:00 pm »
Would You please attach Your max file.
Logged
Mishanin
Newbie
Reply #4 on:
December 06, 2019, 01:37:18 pm »
Quote from: Rokas on December 06, 2019, 01:30:00 pm
attached below
Logged
Hero Member
Reply #5 on:
December 06, 2019, 01:44:46 pm »
Thanks for swift reply.
There is no next segment after 4 to compare and determine what to place teapot or a box. So RC ends with comparison= false = Box.
Hope knowing this will help You create the style You want.
Logged
Mishanin
Newbie
Reply #6 on:
December 06, 2019, 01:52:01 pm »
For a closed spline, wouldn't the next segment after 4 be 1?
Why does it work correctly if it is done on a rectangle spline?
Example attached
Last Edit: December 06, 2019, 01:53:57 pm by Mishanin
Logged
Hero Member
Reply #7 on:
December 06, 2019, 01:57:25 pm »
add edit spline modifier and check which spline is first:
I attach You the image:
RC checks:
is 1st segment shorter than 2? YES = Teapot
is 2nd segment shorter than 3? NO = BOX
is 3rd segment shorter than 4? YES = Teapot
is 4th segment shorter than 5(?) NO= BOX
P.S. Idea to get 1st segment value added for consideration for next RC versions. I agree it would be useful in similar cases.
Last Edit: December 06, 2019, 02:09:12 pm by Rokas
Logged
Mishanin
Newbie
Reply #8 on:
December 06, 2019, 02:08:22 pm »
Too bad it doesn't loop the counter. Thanks
Logged
Mishanin
Newbie
Reply #9 on:
December 13, 2019, 09:14:07 pm »
Is it possible to set one random, so that it would be the same for all arrays, but different for splines?
or in another way how to set a different random on subspline?
Last Edit: December 13, 2019, 10:52:57 pm by Mishanin
Logged
Hero Member
Re: Expression quastion
Reply #10 on:
December 14, 2019, 03:02:18 pm »
Easy wat to do it is using Selector (but it will not place the same segments on the same mat ID subspline).
For index just use random parameter set to Generate on Xspline section.
Logged
Mishanin
Newbie
Reply #11 on:
December 16, 2019, 10:25:43 am »
Not exactly what I wanted.
below is a scene for example
Logged
Hero Member
Reply #12 on:
December 16, 2019, 03:26:36 pm »
Ah, You are targeting the height of the RC object, right?
If so... then...
Logged
Mishanin
Newbie
Reply #13 on:
December 16, 2019, 03:41:21 pm »
It should be exactly two arrays
Logged
Hero Member
Reply #14 on:
December 16, 2019, 04:15:39 pm »
Please, check the parameters.
Uncheck 'No. Blocks or Height' checkbox (RC will calculate height based on the Min/Max number of blocks)
Set Min & Max Block # to value 2
Last Edit: December 16, 2019, 07:17:08 pm by Dragan
Logged
Print
Pages: [
1
2
« previous
next »
RailClone
RailClone Pro (*)
Expression quastion
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
