Author Topic: Maybe a handy feature for railclone  (Read 3166 times)
suppenhuhn
« on: March 20, 2020, 10:19:05 am »
Hi!
I'm using RailClone in many projects and the bigger the project grows i'm facing the same "problem" to pick the right spline-path used by my railclone objects. I'm thinking that in the "base objects -> properties" tab, a little button to select the actual base object used would be a great little feature i'm missing.
Re: Maybe a handy feature for railclone
« Reply #1 on: March 20, 2020, 11:06:11 am »
Added for consideration. Thanks for Your suggestions.
For now You can select splines and segments by quad menu:
« Last Edit: March 20, 2020, 11:38:57 am by Rokas »
suppenhuhn
« Reply #2 on: March 20, 2020, 02:19:01 pm »
Awesome - didn't knew that..helps a lot !!
Thank you  8)
