Author Topic: Metal handrail bug?  (Read 3125 times)
JU4004
Metal handrail bug?
« on: May 23, 2016, 05:20:43 pm »
I'm having problems with the Metal handrail (1 and 2) preset : it's working OK on curved splines but I'm getting gaps in the vertical posts when applied on straight segments splines. Anyone else having this issue?
Thanks!
Re: Metal handrail bug?
« Reply #1 on: May 23, 2016, 06:47:47 pm »
Thanks for contacting us. If the problem your experiencing looks like the image below, this is because there's a vertex on the spline that' s causing the RailClone object to think that a Corner should be added.
To fix this, either delete the vertex of change it to a Bezier, or Smooth type and that should fix the problem!
Many Thanks,
JU4004
« Reply #2 on: May 24, 2016, 01:52:14 am »
Thanks for replying Paul,
Actually, I was having gaps on the vertical segment between each wires (dont have time to post a screenshot right now), but I found out that it was happening only on closed splines. So I just broke one vertex and that fixed it.
