Author Topic: Metal shed panels not fitting together correctly and overlapping on corners.  (Read 2587 times)
chrisc0le
Hi All
Hopefully someone will be able to show me the error of my ways.
I am trying to use railclone to populate the side panels of a metal shed. These are 18cm corrugated panels.
I have been able to play around with the settings and get something like what I need.
However the corners are giving me a big headache. When I eventually do manage to get everything fitting together. The corners seem to have overlapping geometry on one side only.
Hopefully I'm just missing something with pivots or a setting somewhere.
chrisc0le
Thought i'd add an update.
I managed to fix the problem quite easily in the end. I removed the start & end segments (where not required), set all pivots to auto and used transform & padding to position the corner segments manually. Everything fell into place then.
Great! Glad to hear you managed to resolve the issue.
Cheers!
