RailClone => RailClone Pro (*) => Topic started by: djibvongenf on December 09, 2022, 02:19:24 pm
Title: Mirror ending and detail problem
Post by: djibvongenf on December 09, 2022, 02:19:24 pm
Hi All,
im having an issue with railclone to make a sofa following a path. I have two parts. Start and middle.
- The start model is clean but when instanced with a linear following a path, it gets a bit crappy
- The ending is a mirror from the start model but does not reach the end
Any idea why i encounter these problems?
ty
Title: Re: Mirror ending and detail problem
Post by: Michal Karmazín on December 09, 2022, 03:36:04 pm
Unfortunately, just from provided images, it's hard to say what might be causing it. Would you mind to send us (http://forum.itoosoft.com/index.php?topic=3648.0) your scene (or upload it here)? Thanks in advance.
Post by: djibvongenf on December 10, 2022, 10:59:04 pm
Hello, I actually manage to understand more tutorials and remember them.
Im now, unfortunatelybut without surprise, facing a problem which is having a taper effect on the end (as drawn in pink).
The main idea would consider following the cad plan but also having something which looks a bit less than an afghan hound's profile.
Maybe someone could have juicy idea to share?
Thank you
Post by: Michal Karmazín on December 13, 2022, 11:37:34 am
I would say, that modeling such a piece would be the recommendable way in this case.
