Author Topic: Multi texture  (Read 34551 times)
djibvongenf
Multi texture
« on: April 27, 2025, 11:57:01 am »
Hi All,
I have objects witha multitexture applied on each but once distributed on a railclone linear, no material is applied... any idea why?
ty
Re: Multi texture
« Reply #1 on: April 28, 2025, 10:38:10 am »
If the material is applied only to the object(s) used as segment(s), please double-check that the Style > Use Segment Material option is enabled. In case you encounter further issues, could you please specify which renderer you are using and briefly describe your style setup (or upload/send us your scene)? Thanks in advance.
