Author Topic: x rotation  (Read 3802 times)
JI5496
x rotation
« on: February 28, 2017, 05:03:18 pm »
Hello!
I have the following problem:
2 curved splines - one with an offset of the other - between those 2 I want to span simple woodplanks.
I now also have to rotate the planks to make up for the offset of the second spline but railclone seems
to use the curves normals when using x rotation - is there a way to rotate around the world axis?
please see attached image (the green object is what i am trying to achive - the blue one is the railclone object)
I have also attached the max file.
also is this the optimal solution for this problem or is there a better way?
thank you!
Re: x rotation
« Reply #1 on: March 01, 2017, 11:43:46 am »
As mentioned in this "Make an object span two splines" related thread: "Unfortunately this is a tricky problem to solve at the moment. Ideally we would add a new generator that uses two parallel splines, this is already on our to-do list but there are some technical issues that must be ironed out before we can implement it in a release."
In your case a possible solution might to be rotate the RC object, apply the Deform - Vertical mode and to align it with the other spline use the Generator's X Rotation value.
Attaching a modified scene. Hope that helps a bit.
