RailClone > RailClone Pro (*)
Multi texture
(1/1)
djibvongenf:
Hi All,
I have objects witha multitexture applied on each but once distributed on a railclone linear, no material is applied... any idea why?
ty
Michal KarmazĂn:
If the material is applied only to the object(s) used as segment(s), please double-check that the Style > Use Segment Material option is enabled. In case you encounter further issues, could you please specify which renderer you are using and briefly describe your style setup (or upload/send us your scene)? Thanks in advance.
Navigation
[0] Message Index
Go to full version
