Author Topic: Vertical segements are banking with my spline - solution not obvious  (Read 2582 times)
mynewcat
I am following the simple instructions to have vertical segments - but the segments (balusters?) seem to be swerving off.
I'm not sure if it's the spline itself - but I tried using a different spline and they are vertical - and I tried using a library railing preset on my spline, and that worked.
I don't see how many more options around "vertical" deformation I can fiddle with and not get it working.
Some help please?
Re: Vertical segements are banking with my spline - solution not obvious
« Reply #1 on: October 25, 2020, 08:53:03 pm »
Please can you downgrade it to Max2018.
As I remember I had a similar issue.
If you placing Segment by Evenly and getting this problem try to connect to Default and add Transform>Padding Left value...
« Reply #2 on: October 26, 2020, 08:14:43 am »
Thanks for reporting this bug. We will check it.
For now You can fix it as Dragan told.  Or add the same segment to Start Input (You can also transform it to be very small if You definitely do not need it).
mynewcat
« Reply #3 on: October 27, 2020, 11:58:30 am »
Thanks! that worked. I thought I was going crazy!
Yeah, this is odd, please get this fixed ASAP!
