Author Topic: Multiple License server on one Network.  (Read 7478 times)
zules
« on: May 09, 2017, 05:31:36 pm »
i'm actually in a coworking space, where another freelance use Itoo softwares, and a License Server... and mine can't get my license on this network bc of its, and opposite.
Is there any way to clean this pb ?
Thank you !
Re: Multiple License server on one Network.
« Reply #1 on: May 10, 2017, 09:32:54 am »
First let mention, that we strongly recommend you to use just one License Server service per network. A recommendable options would be to add your licenses to existing license server service or separate your networks.
There is a possible workaround by modifying system registry key (the "port" value) listed below to override the port and then manually configure all the clients.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Itoo Software\License Server
If you decide to modify it, please remember you have to configure all clients by setting the network license to the IP of the server instead of finding it automatically. This can be done using the "Change License Mode" wizard after setting Network license mode in the Configure the Network License window. Hope that helps.
zules
« Reply #2 on: May 10, 2017, 08:25:51 pm »
I know for 'just one license" but when you work with other people around that aren't your colleague... you have to adapt yourself !
I think it worked perfectly... Thx !!
zules
« Reply #3 on: October 29, 2019, 01:35:19 pm »
I re-open this topic as I just bought my renewal for RC 4.
I also updated my LS to the last version.
I tried to change into Regedit the port server as usual, but the license server doesnt seems to understand the change and keep connecting through port 16720.
Any tips to solve this ?
Thanks ! :)
zules
« Reply #4 on: October 30, 2019, 10:06:01 am »
Ok, I found the solution.
I also activated the port under the HKEY_LOCAL_MACHINE\SOFTWARE\Itoo Software\License Server category, not only HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Itoo Software\License Server
Hope this help somebody.
Peace
« Reply #5 on: October 30, 2019, 03:55:46 pm »
Glad to hear you fixed the issue, thanks for letting us know and sharing the solution.
All the best,
