Author Topic: Multiple Monitors  (Read 169647 times)
dirkmyers
Multiple Monitors
« on: May 20, 2025, 09:58:58 pm »
I work on multiple monitors as i am sure everyone does. Is there a way where the railclone style editor comes up on a different screen rather than the primary monitor?
Re: Multiple Monitors
« Reply #1 on: May 21, 2025, 09:55:10 am »
The Style Editor window's size and position are stored in the following system registry key:
HKEY_CURRENT_USER\SOFTWARE\Itoo Software\RailClone\Style Editor
I’ve done some quick tests using a secondary monitor, and it appears to behave correctly — the size & position is successfully restored.
Thanks in advance for any additional details you can provide - your feedback is always valuable, both for us and for other users who might encounter similar issues.
dirkmyers
« Reply #2 on: May 21, 2025, 04:12:58 pm »
When you say "behave correctly" do you mean it pops up on a different monitor? not your primary? Thanks
« Reply #3 on: May 22, 2025, 09:21:07 am »
Yes, based on my tests, once the Style Editor window is positioned and closed on the second monitor, it correctly reopens in the same location (on the second monitor) — even for new RailClone objects.
dirkmyers
« Reply #4 on: June 04, 2025, 03:57:46 pm »
Does not work for me. is there any logs i can upload to see if there is a fix?
« Reply #5 on: June 05, 2025, 09:32:14 am »
Could you please briefly describe the behavior you're experiencing on your system? Does the position reset with every new RailClone object, after a 3ds Max reset, or following a system reboot? Also, please let us know your software configuration - specifically your OS, 3ds Max, and RailClone versions. Thanks in advance for any additional details you can provide.
