Author Topic: multiple y spline facade?  (Read 4745 times)
FQ1241
« on: June 26, 2017, 06:51:32 pm »
I have a facade that needs to lean forward creating an overhang at the top of only ONE point of the facade.
Attached shows in plan the blue line is the upper slab and the yellow the lower....
As if I used an array with the x and Y spline where the Y is not consistent throughout the model as shown in the tutorials.
Any suggestion? thanks!!
Re: multiple y spline facade?
« Reply #1 on: June 29, 2017, 12:19:46 pm »
A possible work-flow would be to split the façade and on that part adapt the RC object to a "help Surface" - created from these splines for example by CrossSection & Surface modifiers. Just please take note, that the projection is performed on the Z axis and involved objects need to aligned correspondingly. Attaching a sample scene. Hope you'll find it useful.
