Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Need some help with Hexagon alignment
« previous
next »
Print
Pages:
1
2
Author
Topic: Need some help with Hexagon alignment (Read 6434 times)
Hero Member
Re: Need some help with Hexagon alignment
Reply #15 on:
January 05, 2021, 06:03:42 pm »
Glad to help
Well, the corners are always a little bit tricky. With your pattern, I will probably prepare/remodel separate segments for the corners inputs but then the generator should be based on L1S nested with some A2S/L1S to fill up the default wall surface. Clipped A2S will be hard to track where to finish with the corner and where to finish with the start/end segment.
Logged
IVORM
Newbie
Reply #16 on:
January 05, 2021, 08:13:20 pm »
Hi Dragan,
Because I’m still a newbie I find it very helpful reading your solution. Is it also possible to keep both splines separate and adjust the height of one spline with a transform node so the pattern match up?
Logged
Hero Member
Reply #17 on:
January 05, 2021, 08:33:31 pm »
Yes, of course. You can export X and Y translation parameters and play for each of the spline individually.
Logged
IVORM
Newbie
Reply #18 on:
January 05, 2021, 08:51:10 pm »
Thks Rokas! You and Dragan are a great help to me. My next question About facade cladding is on another thread (keeping the forum clean)
Logged
Print
Pages:
1
2
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
