Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Need to rotate RC 90 degrees
« previous
next »
Print
Pages: [
1
Author
Topic: Need to rotate RC 90 degrees (Read 4598 times)
TL1895
Sr. Member
on:
February 02, 2016, 03:03:56 pm »
So that it will be vertical, instead of laying flat (as pictured.)
Thanks in advance
TL1895
Logged
ITOOSOFT
Hero Member
Re: Need to rotate RC 90 degrees
Reply #1 on:
February 02, 2016, 03:19:09 pm »
Hi!
If you're using clipping splines and Extend X/Y size to area the easiest way is to just Rotate the whole RailClone object so that it's local Z axis is pointing towards the wall. There's a section at the bottom of the
Clipping Splines
chapter of Next Steps with RailClone called "Using Extend X/Y Size to Area to create Vertical styles." that you might find helpful.
Thanks!
Logged
TL1895
Sr. Member
Reply #2 on:
February 02, 2016, 03:47:59 pm »
Thanks Paul, I am relieved that it was something simple!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
