Author Topic: Nested array only works on single sided-spline  (Read 8574 times)
NF4889
« on: March 07, 2024, 12:51:14 pm »
I've used a technique of nested arrays to get Y height from marker data, but now my array only works on single segment splines.
Any ideas what's going on here?
Re: Nested array only works on single sided-spline
« Reply #1 on: March 07, 2024, 01:15:38 pm »
To avoid the necessity of adding Markers for each spline segment, you can simply "deactivate" beveling of these corners by setting the Bevel Mode to Node and wiring an "empty Segment" to the Corner Input. Please find attached the modified scene (240307_brickFeature1stVersion_iToo.max).
