Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
New libraries weird behaviour (Railclone 3.04b + 3ds 2012 + Corona 1.6.2)
« previous
next »
Print
Pages: [
1
Author
Topic: New libraries weird behaviour (Railclone 3.04b + 3ds 2012 + Corona 1.6.2) (Read 9272 times)
zetes
Newbie
on:
August 01, 2017, 03:24:26 pm »
Hello.
I am exploring Railclone 3 - (version 3.04b - I am planning to renew my subsrcitpion) and I have noticed some weird behaviour with new libraries.
Concrete Cladding Randomised example:
https://www.screencast.com/t/Of5lX15C
https://www.screencast.com/t/47FQmaQozq
Concrete cladding fixed example:
https://www.screencast.com/t/qlFmxeKGe
just simple scene with HDRI + new railclone library + spline + Corona 1.6.2 + 3ds 2012
Am I doing something wrong?
Best regards.
Logged
ITOOSOFT
Hero Member
Re: New libraries weird behaviour (Railclone 3.04b + 3ds 2012 + Corona 1.6.2)
Reply #1 on:
August 01, 2017, 04:04:35 pm »
I would suggest you to double check, that
the instancing engine is turned off
. Thought, when the Corona renderer is detected you should receive the message attached (
"Selected style doesn't support instancing with current Renderer. Display -> Use Instancing Engine is set off"
), might be that's enabled.
If you'll be able to reproduce it on a minimal scene, which you can
send us
, it would be great. Thanks in advance for any further comments on this issue you can share about it with us / our user community.
Last Edit: August 01, 2017, 04:06:26 pm by Michal Karmazín
Logged
zetes
Newbie
Reply #2 on:
August 01, 2017, 07:50:01 pm »
Hello.
Yeah, I knew about turning off instancing engine in Corona - I've checked and it was disabled.
But... I think I've found a way to reproduce this weird behaviour.
When I start fresh new scene - enable corona renderer and put Railclone 3 object with one of the new library presets - everything works OK.
Steps to reproduce:
1. Start fresh new scene and enable Corona renderer.
2. Add Railclone object with for example "Concrete Cladding Fixed" BUT WITH "using" Standard material.
3. Hit render.
4. Go to Railclone Library and change "using" Standard material to Corona material.
5. Warning about Instancing Engine pops out - and in "Display" it is unchecked.
but from now it renders wrong - even if you create new railclone object or create new scene. I had to restart 3ds max to disable this behaviour.
Hope it helps.
Logged
ITOOSOFT
Hero Member
Reply #3 on:
August 03, 2017, 11:53:36 am »
We've been doing some additional tests on 3ds max 2012, RailClone Pro 3.0.7 & Corona 1.6.2, but up to now we can't reproduce any similar troubles. Which
On Duplicate Material
option (Use scene material, Replace from Library, Ask to user) are you using?
If possible, please
send us
anz affected scene and we'll check it here.
Best regadrs,
Logged
zetes
Newbie
Reply #4 on:
August 07, 2017, 06:21:59 pm »
i am using "Replace from Library" option.
I am attaching scene with this problem.
Logged
ITOOSOFT
Hero Member
Reply #5 on:
August 11, 2017, 02:59:31 pm »
Big thanks for the provided scene. It's linked to RC's API implementation done by Corona team - it has been already reported. Once again, thanks for all your feedback.
Best regadrs,
Logged
zetes
Newbie
Reply #6 on:
November 08, 2017, 02:51:11 pm »
Is mentioned issue fixed in Corona 1.7 maybe?
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
