Author Topic: Y Evenly not distributing equally?  (Read 5288 times)
darthmurda
    • MichaelJohnsonCg@gmail.com
« on: October 06, 2015, 03:54:06 am »
I'm having problems understanding why the Geo in the Y evenly slot is not distributing equally under the window planes. If I used a Sequence Operator in the default it works but I thought this is the way it should work within the Y Evenly slot. Sorry, I'm new to this.
Re: Y Evenly not distributing equally?
« Reply #1 on: October 06, 2015, 11:18:39 am »
The Evenly modes are designed to place segments at regular intervals and slice the default segments to fit in the remaining spaces. In this case it looks as though you would like the entire height of both segments to be used with no slicing, in which case the sequence operator is a much better choice.
Because it looks as though the segments have slice disabled, you will get a lot of overlapping and unexpected behaviour using Evenly segments unless you use Distance mode with Adaptive and Justify turned off and a distance value that is a multiple of the height of the default segments.
I hope that helps,
Many thanks!
darthmurda
« Reply #2 on: October 06, 2015, 05:06:09 pm »
Thanks so much for your help! I really appreciate it!
