Author Topic: URGENT ! No Geometry Error  (Read 15897 times)
HU0164
« on: March 17, 2025, 02:47:28 pm »
I'm importing a 2D DWG file and I'm getting a “No Geometry” error message with the 2 Curbs objects from RailClone.
If I choose another object it works.
If I create a line in 3DS Max, it also works.
However, it's impossible to assign a “curbs” object to a line from DWG.
Re: URGENT ! No Geometry Error
« Reply #1 on: March 17, 2025, 03:24:58 pm »
I'm sorry to hear you're facing trouble with it. Curb styles use the spline's Material IDs to assign different types of curbs (ID 1 for normal curb, ID 2 for drop curb), so feel free to set the corresponding part(s) of the spline to the appropriate Material ID. Let me mention that, as posted here on our forum:
"... upon my experience, in case of importing splines from a .dwg file, its Color is used for generating the 3ds max Material ID. If you want to avoid the Edit Spline modifier step - assigning the Red color to such spline (layer) should result in ID 1 / Yellow as ID2 (as the Red color should be indexed 1 (Yellow 2) in AutoCAD)."
HU0164
« Reply #2 on: March 17, 2025, 04:20:08 pm »
Well done!
It's definitely a Material ID problem.
Color 7 on Autocad = ID 7 3DS Max
Thanks for your help.
