Author Topic: NO ACTIVE GENERATORS  (Read 3215 times)
SX0536
« on: October 28, 2021, 09:38:13 am »
I'm running into a problem trying to select a spline with a new RC Library pre-set. It keep telling me I have no active generator. If I start a blank array, it works fine. I installed uninstalled a couple of times with no luck. 3DS Max 2022 and RC 4.3.2
Re: NO ACTIVE GENERATORS
« Reply #1 on: October 28, 2021, 09:41:25 am »
Sorry to hear you're facing that issue. Could you let us know the preset you're using? If it's a particular spline causing the issue, could you also send it to us in a simplified max scene?
SX0536
« Reply #2 on: October 28, 2021, 04:54:05 pm »
Thanks for the reply,
It's the civil engineering bridge library 1 way 1 lane, it that doesn't want to work. Everything else seems fine.
I attached a simple scene.
Chris
