Author Topic: RailCloneColor and nested RC objects  (Read 3951 times)
nicobulo
« on: September 14, 2017, 02:51:49 pm »
Hi guys,
I'm trying to nest railclone objects,
on the geometry side evrything is ok
I'm using RailcloneColor map for the source RC objects which works fine for them ( see RCa & RCb ),
but when everything is nested under another RC object I can't get the randomness of the RCColor map anymore,
Anyone knows how I could get the same effect from the source objects to the big nested object ?
Thanks !
Re: RailCloneColor and nested RC objects
« Reply #1 on: September 14, 2017, 04:21:58 pm »
I'm afraid, the RailClone Color map doesn't support nested objects. We'll check if that can be solved somehow in future versions, but I can't confirm you if that'll be possible. Thanks for your comprehension.
nicobulo
« Reply #2 on: September 15, 2017, 02:33:25 pm »
Ok, thanks for your answer,
that's unfortunate but i managed to achieve it by using another multimap system.
