Author Topic: Padding not working in Clipping Area mode (A2S)  (Read 4118 times)
Nir Sullam
« on: April 17, 2015, 12:52:49 pm »
Hi all
I have been trying to shift/offset  the main surface area so that it does not penetrate the surrounding frame.
I tried the padding but this does not affect the Array2S .
Version 2.46
Re: Padding not working in Clipping Area mode (A2S)
« Reply #1 on: April 17, 2015, 02:23:21 pm »
Hi Nir,
I'm afraid this is a limitation of the Generator > Padding feature. It does not work with Extend X/Y Size to area. In this case I would recommend aligning the frame so that it runs on the outside of the spline instead of the inside.
Many thanks,
Nir Sullam
« Reply #2 on: April 17, 2015, 02:26:18 pm »
Thx
I was afraid that wiould be the answer. In thios case the frame is hiding what is beneath so no harm but I guess there would be cases it will be a must.
Nir
