RailClone => RailClone Pro (*) => Topic started by: Pixual on May 20, 2020, 12:38:33 pm
Hi all,
I'm working on multiple scripts and I'm wondering how to solve the following:
I have tiles for which I use two types of patterns: 1. the 'segment > herringbone' macro and 2. the 'hexagonal padding' macro. In addition to this i'd like to change sizes of the tiles without scaling the texture, so I enabled the 'apply box mapping' feature in the segment node. When switching between the two macro's the tiles will rotate by 45 degrees. I'd like to add the (fixed) rotation number into the 'mapping>rotation' parameter of the segment node by switching between two numeric nodes via an index number (which corresponds to the index number for the tile bond macro selection).
Is selecting a numeric by index possible in Railclone?
Thanks, greetings,
Jakob
Yes, it is possible. Just add a new Arithmetic node and use IF statement to act as a selector:
e.g. You can use Inputs 1-4 as some values and Input5 as Selector Index
Input1 = 20
Input2 = 60
Input3 = 10
Input4 = 33
Input5 set to 1 - 4
RETURN
If(Input5==1,Input1,
Input5==2,Input2,
Input5==3,Input3,
Input4);
so. if You set Input5=3 your output will be value 10, for Input5=1 output will be 20 etc.
Thanks Dragan for the quick reply!
When i tried this out, two things occur.
I used the following expression:
RETURN
if (Input3==1,Input1,
Input3==2,Input2);
In the arithmetic node the first input is a 'constant' with a value of 45, second input is a 'constant' of 0 and the third input a 'numeric' which could be 1 or 2.
When i Evaluate this it says:
Compile error. Wrong number of arguments in function: "if" at line 2:
Second point, if i try to wire this to an input for a segement mapping rotation it gives a warning as seen in the attachment. Because of the compile error it doesn't seem to give any output yet, any idea how to solve this?
Greetings, Jakob
In your case it is enough:
RETURN
if (Input3==1,Input1,Input2);
Many Thanks Dragan! This works :D
Hi!
The solution worked for a two choice selector. I'm working at something else and I'm in need for a selection of more input values. For a multi-choice selector as stated above by Dragan the solutution always gives the error I mentioned, even if I copy them. Is there something I do wrong entering these values?
Jakob
It is not your fault ;D
My syntax on the previous example with multiply inputs was wrong ::)
For example, you have 5 inputs:
Input1
Input2
Input3
Input4
Input5
and one to use as selector
Input6
If statement is look like this: IF(A,B,C) meaning; If A is true then B else C.
Return
IF(Input6==1,input1,
IF(Input6==2,input2,
IF(Input6==3,input3,
IF(Input6==4,input4,
input5))));
For values 1-4 you are checking if input#==XX and if some of those are true that point will be your output and if none of those 4 is true input5 (the last one) will be taken as output.
So basically you are making a loop until the last one.
Sorry for previous confusion :-[
Here is the file containing the Macro for 10 numeric inputs.
Please, let me know if you need something more.
Best Regards
Having needed this today I first want to thank you for explaining the setup.
That said, would this kind of setup not be a lot easier if input would also take an input as value ?
return input(inputX);
I mean the if(then,(if(then, else)) setup will quickly become not so fun to write and maintain if you need 100+ inputs for some reason
you are right, but as far as I know, this is not possible in Railclone.
The only attributes that can be used as some sort of counters are SegmentCounter and values related to the Base Spline as the Spline/Section Position, the SectionCounter, the Arry Counter and for animation, you can use Time.
There are no loops or counters to be used as an index.
