Author Topic: Object scale change  (Read 4118 times)
lukx
    • lukxCGI
Object scale change
« on: December 14, 2020, 09:29:35 pm »
Is it possible to do this kind of string chair back with railclone.
So the strings are getting shorter closer to the arms?
Re: Object scale change
« Reply #1 on: December 14, 2020, 10:42:06 pm »
Hi.
Have You tried with this technique already?
I don't know better way for such structure.
lukx
    • lukxCGI
« Reply #2 on: December 15, 2020, 06:53:03 am »
Thank you Rokas but I can't get the rope to follow the spline(rotating) also top and bottom splines aren't excluded and the scaling of shortest ropes is too flattened.
« Reply #3 on: December 16, 2020, 03:20:08 pm »
Hi again.
This is my attempt at this chair. Splines used should have some obvious direction so RC can make geometry for them. Otherwise- not possible. As a final tweak You can add FFD on top of RC itself.
Hope this helps at least a bit.
lukx
    • lukxCGI
« Reply #4 on: December 16, 2020, 03:36:52 pm »
Thank you Rokas, looks awesome! What do you mean "Splines used should have some obvious direction so RC can make geometry for them" ?
« Reply #5 on: December 16, 2020, 03:42:55 pm »
You could not align rc segment because they are too vertical. I have increased the angle they are sloping.
lukx
    • lukxCGI
« Reply #6 on: December 16, 2020, 03:45:45 pm »
Oh, got it, thanks for this tip.
