Author Topic: off/on and Arithmetics?  (Read 3423 times)
IT1371
« on: September 18, 2018, 10:54:00 am »
I have this simple expression in an Arithmetic operator:
Code: [Select]
if(input1>input2,1,0);Ideally I would just attach it to the on/off parameter of a generator or a segment, but it is not supported.
Is there a way around this? I can't use a Conditional operator..
Re: off/on and Arithmetics?
« Reply #1 on: September 18, 2018, 11:34:59 am »
Although it gives You error:
It lets You do what You want. I have used it in similar situations without problems too.
Don't forget to add return constructor in front of Your expression.
IT1371
« Reply #2 on: September 20, 2018, 07:58:06 am »
Turns out it didn't work in the first place because I did not put the "return". I thought I can start with an "if"..
Thank you!  ;D
