Author Topic: parametric (null) segment  (Read 17042 times)
harumscarum
    • harumscarum's portfolio
« on: December 26, 2013, 11:07:52 pm »
to create Z offset in the beginning of Sequence node I have to add segment with required Z and X=Y=0 from scene.
would be great to have invisible parametric segment with x, y, z dimensions for that purposes.
Transform node is not solution because i dont need shift at the end of Sequence.
« Last Edit: December 26, 2013, 11:11:39 pm by harumscarum »
Re: parametric (null) segment
« Reply #1 on: December 27, 2013, 05:35:51 pm »
Currently it's possible to create an virtual segment with dimensions, adding a empty segment node (without a mesh) and setting the size with paddings.
Anyway, i don't understand well how do you add a Z offset in this way, since this dimension is not taked in account for the next segments... please would you post a test scene to see it in detail ?
