Author Topic: Overlapping tiles by half  (Read 1238 times)
OT3376
« on: December 01, 2025, 01:04:22 pm »
Hi. Another tile problem. Probably a simple solution. I want to have the tiles half overlapping as in the attached screenshot but any parameters I adjust seems to break it.
maxfile attached.
Re: Overlapping tiles by half
« Reply #1 on: December 01, 2025, 01:39:36 pm »
For this purpose, you can use negative values for the Padding parameter - in this case, the Top Padding. To ensure consistent values across all Segments, the recommended approach is to use Transform Operators with the Top Padding Parameter exported and wired to a Numeric Parameter. Please find attached a modified version of your scene (251201_RAILCLONE_TILED_ROOFS_ITOOSOFT_REV.max). I hope this helps.
OT3376
« Reply #2 on: December 01, 2025, 05:19:55 pm »
Thanks!
