Author Topic: Trim X&Y-Evenly By Half YSectionLength  (Read 4648 times)
RC2292
« on: April 12, 2021, 07:56:56 pm »
I'm wanting to trim my 2S generator X&Y Evenlies by half the YSectionLength but not really sure where is best to input the expression in a Transform node to do this.
Sometimes I'll wat to trim the top portions and sometimes the bottom portions.
It should always trim the same half for all Splines in a Generator, never mixed.
Re: Trim X&Y-Evenly By Half YSectionLength
« Reply #1 on: April 13, 2021, 07:30:08 am »
Good Morning.
Attaching my solution. Hope this helps.
Let us know if You have any further questions.
« Reply #2 on: April 13, 2021, 08:19:58 am »
I think he wants to trim verticals as well.
« Reply #3 on: April 13, 2021, 08:44:34 am »
Here is a quick one but I`m sure it can be done with some simple style...
« Reply #4 on: April 13, 2021, 08:52:30 am »
In that case style gets a bit more complex. added another generator, one for x evenly one for y evenly.
I am not sure it can be made in one simple generator.
P.S. I see, Dragan, You upgraded You max version ;)
« Reply #5 on: April 13, 2021, 09:23:52 am »
 ;D Yes, I`m going to 2023 soon  ;D
@Rokas
Please check my style, I`m sure You will understand it but there is an issue with the `bounding box`.
Disconnect Null from StartTop and you will see what I`m talking about.
« Reply #6 on: April 13, 2021, 09:38:22 am »
nothing happens:
« Reply #7 on: April 13, 2021, 09:58:25 am »
Yeah, I had some issue with a slice on the rounded spline on some critical point so connecting a Nell to Corners terminated this slice. (can't remember parameters values)
Never mind, just a glitch that can be easily solved.
« Reply #8 on: April 13, 2021, 10:02:03 am »
Try parameters 3 / 100 / 100   (disconnected StartTop)
RC2292
« Reply #9 on: April 13, 2021, 10:19:22 am »
Morning and thank you both for the swift response.
Dragan; Yup that's spot on but I am getting this issue with residue geometry.
It's what prompted me to ask for help. Although mine was MUCH worse and I wasn't just getting it on curved splines.
Is that the issue with the bounding box?
RC2292
« Reply #10 on: April 13, 2021, 10:23:25 am »
Just posted whilst you added your post Dragan.
Yes I think this is the same issue although mine appears even if I leave StartTop connected
RC2292
« Reply #11 on: April 13, 2021, 10:30:16 am »
Here's a more pronounced example.
With StartTop connected but seems to only occur with curved splines.
« Reply #12 on: April 13, 2021, 10:53:08 am »
Yes I noticed this bug while solving the style and already logged to our bug system. Thank You.
« Reply #13 on: April 13, 2021, 10:55:31 am »
Try connecting Null segment to all the corners inputs.
RC2292
« Reply #14 on: April 13, 2021, 12:38:23 pm »
No, unfortunately adding Null to all the corners doesn't seem to be having any effect.
