RailClone => RailClone Pro (*) => Topic started by: Nali on April 26, 2017, 10:32:39 am
Title: Padding between compose
Post by: Nali on April 26, 2017, 10:32:39 am
Hi Guys,
Thank you for your great plugin. It greatly help me to speed my workflow.
I have got a problem and don't know how to do it properly.
I try to use railclone to do like my attach picture.
(https://drive.google.com/uc?export=download&id=0B5EcAQY23Ia7S0ExRXNKQlpwcVU)
To do that i use an old method i see on the forum, and use padding righ between object to have the properly gap.
The railclone's picture is from railclone lite this is why i have got only 3 obj and not 5, but the process is the same.
(https://drive.google.com/uc?export=download&id=0B5EcAQY23Ia7c1JFeUNQc0w4R1k)
But i don't know how to do the gap beetween every compose wich is every 5 object ?
How do i do that ?
Any hint ? :p
Title: Re: Padding between compose
Post by: IT1371 on April 26, 2017, 11:17:00 am
You could try and connect a Transform operator (with padding) to the output of each Compose.
Post by: Michal KarmazĂ­n on April 26, 2017, 01:00:59 pm
Adding an empty Segment and adjusting the Padding / Fixed Size of such Segment will do the trick. Attaching a sample scene.
Post by: Nali on April 26, 2017, 02:47:57 pm
Oh ! Nice !
I use that tip a lot with forest but don't think of it for railclone.
Thank you very much for your answer !
