Author Topic: Windows Facing  (Read 2481 times)
GT4505
    • claar.be
Windows Facing
« on: September 15, 2022, 06:56:17 pm »
When modeling we often do 4 sides of a building at once, but sometimes we have problems with opposite windows (or other railclone objects).
See attachment.
It's a clipping plane array 2S. Is there a way to avoid this? (we prefer not to detach the splines)
Vincent
Pieter van Stee
Re: Windows Facing
« Reply #1 on: September 16, 2022, 10:32:04 am »
Hello Vincent,
You have several options to help to tell RailClone which splines should generate a new array, and which are clipping areas within an existing array. They are as follows:
 - Complete uses the original RC2 behaviour, stacked splines are alternatively include or exclude geometry. In this mode you can get issues with splines on opposite sides of a building.
- None treats each spline as unique, overlapping or stacking splines have  no effect.
- By Material ID allows you to assign a material ID to the splines to determine which should be considered to belong to the same array.
I hope that helps,
GT4505
    • claar.be
Re: Windows Facing
« Reply #2 on: September 19, 2022, 10:35:23 am »
Great, that works.
Thanks for explaining!
Only thing we had to change to use it with right ID's is using a conditional to check the ID's instead of the limits.
Vincent
Pieter van Stee
