Author Topic: RailColne 5.2.6 Corona 8 - Color problem  (Read 2776 times)
SamyC38
« on: August 12, 2022, 04:46:39 pm »
Hi there,
I am a beginner for the use of railclone and I have a color problem of the elements constituting my railclone.
I used the test file proposed with the explanatory booklet (l1s_exercice_end.max) of the pluggin but I do not understand why when I create a new railclone the elements do not keep the color of the basic elements.
On the image the pillars in the middle are in green (railclone that I created).
When I copy the properties of the railclone of the demonstration file it works (on the left on the image the properties are saved).
However, I checked and I have exactly the same parameters on the 2.
What does one know why?
Thanks for your help
I have the latest version of the railclone Pro (5.2.6), 3DSMAX 2023 and Corona 8
Re: RailColne 5.2.6 Corona 8 - Color problem
« Reply #1 on: August 15, 2022, 09:31:21 am »
Thanks for contacting us. By default RailClone does not use the materials assigned to the source geometry. You have two options:
- Enable Style > Geometry > Use Segment Material
- Manually assign the material to the RailClone object. In this case you will need a single sub-object material that works on all the source objects
I hope that helps,
SamyC38
« Reply #2 on: August 16, 2022, 05:46:07 pm »
Thanks so much Paul,
It's ok right now
