Author Topic: Parameters Overhaul  (Read 2653 times)
DT
Parameters Overhaul
« on: January 29, 2022, 03:07:28 pm »
Hi Itoo,
I was wondering if you guys were planning a UI overhaul of the way one can view/change parameters in the command panel. If for instance I create a style with +30 Parameters it gets kind of complex to look for the correct parameters. It would be nice if you can for instance group things into a seperate Rollout or similar.
Also for the RC spline instead of working with IDs to change the markers, would be nice if it was with names, like the selector for instance.
Thank you for the hard work and kind regards.
Re: Parameters Overhaul
« Reply #1 on: January 31, 2022, 10:14:04 am »
Thanks for the suggestions. We have some ideas for parameters, including things like adding dividers, to try and organise them a little better.
I agree with you about the ability to add drop-down lists to the markers. I'll add that one to the wish list.
All the best,
Adnan Malkoç
« Reply #2 on: January 31, 2022, 11:44:26 am »
Hi Paul,
I'm wondering how long is your (actually our) wishlist?  :D I'd like to see a photo from your office with a whiteboard which has thousand notes on it.
Regards
« Reply #3 on: January 31, 2022, 11:48:26 am »
Ha ha - thankfully our wishlist is virtual, otherwise we wouldn't have enough wall space for it! :)
DT
« Reply #4 on: February 01, 2022, 01:48:48 pm »
Thanks for the reply Paul, well appreciated.
