Author Topic: rotation around spline  (Read 2632 times)
lukx
    • lukxCGI
« on: October 28, 2019, 06:45:12 am »
Is there a way to achieve this kind of effect for hair brush bristles? How they are rotated around the head differently based where they are. I also tried to add surface but doesn't seem to work .
https://www.conranshop.co.uk/ak-protection-pneumatic-brush.html
Re: rotation around spline
« Reply #1 on: October 28, 2019, 08:30:52 am »
I cant find solution with RailClone, but maybe ForestPack can help with Path distribution mode and In Vertex Positions Mode:
lukx
    • lukxCGI
« Reply #2 on: October 28, 2019, 09:24:18 am »
hmmm it helped with rotation in Z but I still need the bristles to be at angle in vertical position like in my raiclone and with forestpack I can't do it somehow.
Ok I just added taper modifier on top of forest and it took care of it (too bad that it's destroying a bit , shape of bristles but I guess the're no way around it.)
Thank you Rokas!
« Last Edit: October 28, 2019, 09:41:25 am by lukx »
lukx
    • lukxCGI
« Reply #3 on: October 28, 2019, 09:46:10 am »
Oh changing direction made everything perfect !
« Reply #4 on: October 28, 2019, 09:50:37 am »
Yes surface normal slider helps, hopefully this result satisfies.
Thanks for sharing this nice example of ForestPack usage.
