Author Topic: Parametric rail.. again  (Read 10034 times)
« on: May 17, 2018, 02:41:14 pm »
If anyone can help me with this, please...
I have to set up a numerous rails with different setups around few buildings.
I just need good start position. I`m trying for past 6 hours to solve all parameters that are required :( ...
I don`t know if image explains the problem but I need to setup parameters for:
- variable height,
- variable evenly divisions,
- variable position of sphere group set (two spheres)  from the top of the rail
- variable size of the glass panel...
The Biggest problem are combined Evenly distribution for spheres&poles (cant see how to place sphere section between Evenly distributed poles)  and of course corners...
I know the RailClone is the best tool for this type of problem.. just  :o ...
Thank you for any help.
Best Regards
« Last Edit: May 17, 2018, 02:48:16 pm by Dragan »
Re: Parametric rail.. again
« Reply #1 on: May 17, 2018, 02:51:57 pm »
You added segments in max file, that's great. Could You please also compose a form and preliminary configuration for it. I am not sure about some details of Your sketch.
« Reply #2 on: May 17, 2018, 04:35:36 pm »
eg:
the `green evenly pole` is only on Evenly position, not on the Start/End/Corners...
the `wire spline` should bend on the Start/End and OUTSIDE corners (this is my biggest issue), on the inter corner should just bevel...
« Last Edit: May 17, 2018, 04:40:59 pm by Dragan »
« Reply #3 on: May 18, 2018, 11:21:03 am »
Can You please attach what You already have, so I don't need to redo everything from scratch?
« Reply #4 on: May 18, 2018, 11:38:13 am »
ah... this is from another CAD..
I do not use MAX as my primary modeling tool... that is why I bought RC and FP so I can create complex stuff with my imported segments
My primary problem is how to place a new segments between Evenly distributed segments...
And second is how to `break`  corner position and place the `bend wire segments`
.. and please do not waste too much time on my problem, you already been very helpful on my "Compose  Pattern" problem....  I'm going to crack it somehow...  ;)
« Last Edit: May 18, 2018, 11:46:02 am by Dragan »
« Reply #5 on: May 18, 2018, 11:44:04 am »
please attach that cad.
« Reply #6 on: May 18, 2018, 12:13:19 pm »
Here is my first RC attempt..
Since I`m still learning but through work I do not have time for more detailed reading of manual or tutorials
I still have some issues with Compose and Segment operators so this RC generator is full or single L1S
... so... I set it on the side for a few hours to clear my mind and I will probably start all over again  with the segments from the first post..
« Last Edit: May 18, 2018, 12:15:50 pm by Dragan »
« Reply #7 on: May 18, 2018, 01:07:25 pm »
I would still want to get Your cad. I would use that to prepare geometry for RC.
« Reply #8 on: May 18, 2018, 01:31:08 pm »
Hahaha... you are very persistent..
It is IronCAD so I will have to export geometry to dfx/3ds format to import ito 3DSMAX... but I do not have anything more then this segment from the images. I just make this part to show dimensions...
Now I have to call my wife to start  my home computer, go to Teamviewer export CAD file..  ;D ;D ;D whole bunch of procedures just for peace of fence  ;D ;D ;D ;D ;D
« Reply #9 on: May 18, 2018, 01:44:24 pm »
Ahhh... you want to slice/cut my geometry for new segments....
So that means I need new approach :D... so much L1S is not good? :D
« Reply #10 on: May 18, 2018, 02:08:06 pm »
L1S is good approach. You have too many L1S generators to handle.
« Reply #11 on: May 18, 2018, 02:20:08 pm »
Yes I know... I wanted to do as much as parametric... to change almost every part of the Railway setup..
Here is the CAD for segments... I get it now... You are going to slice/cut it all over...
Thank You
Best regards
« Reply #12 on: May 18, 2018, 02:29:36 pm »
Just one more thing. I will need option on/off for Glass panels (so I assume this is one/two horizontal cuts more?)...
Thank You again for Your unselfish support!
Best Regards
« Reply #13 on: May 18, 2018, 02:32:45 pm »
I will tackle this on Monday. If You have any progress Yourself please share.
« Reply #14 on: May 18, 2018, 07:46:29 pm »
Thank You... Please don`t do anything before because I just got request for more variations  ::) :o :(
I`ll make my new attempt with less generators and then we can see about any potential issues.
Best Regards
