Author Topic: Parametric rail.. again  (Read 10066 times)
Re: Parametric rail.. again
« Reply #15 on: May 19, 2018, 09:24:52 am »
I got new setup request from the client for the Fence rail.
Here is my initial generator. Segment are vertically sliced out of the initial setup.
It will probably expand to parametric variations for the master height and size of the segments `inside` but for now this is a good start position.
I have few issues marked as red notes. So I appreciate if anyone have time to look and make some comments.
Best Regards
« Reply #16 on: May 21, 2018, 04:16:59 pm »
I still have problem how to achieve for each spline segment to have odd or even number of division adapted to distance set at Evenly Distance mode.
I took a look into manual and Conditional operator regarding segment X counting but could not crack any solution  :(.
I do not know if my idea is make any sense but I hope it is possible. If not, there is new e.r.
Best Regards
« Reply #17 on: May 21, 2018, 04:20:05 pm »
I am examining Your scene right now. Do not have a solution Yet though.
« Reply #18 on: May 23, 2018, 07:06:15 am »
I'm close to finish the project, and there are only fences left. There seems to be no simple solution for an odd/even Evenly division on the Spline segment so I guess I will set various Mat ID to the Spline and target the Evenly Distance by Mat ID.
It is not to much trouble since this is only one house (for now) but I would like to see it as a new option (img)
Best Regards
« Reply #19 on: May 23, 2018, 07:55:06 am »
I will add this suggestion to our todo list.
Thank You for this suggestion.
« Reply #20 on: May 28, 2018, 09:42:30 am »
For the second project in a row, I have a need for even/odd distribution with Evenly mode...
Is it possible to see this option in near future?
Thank You.
Best Regards
