Author Topic: Parametric sunshade  (Read 9774 times)
zules
Re: Parametric sunshade
« Reply #15 on: May 21, 2020, 06:41:43 pm »
Yes sure, it can be a fake one, or just a stack of 5-7 segments or so maybe ?
« Reply #16 on: May 22, 2020, 11:59:46 am »
Ok. Then the fake one will be quite simple.
Although RC is powerful in computing keep in mind that manipulating with pre-prepared model components is much faster.  For instance, the present Macro is based on calculations on how each segment will be placed/rotated so it could take some time to generate if you are working on a large scale scene.
On the other hand, if you use pre-prepared segments and just use randomize/sequence/compose operators etc, RC will use the benefit of instancing and everything will be much faster and memory-efficient because generating will be based on simple "segment-stacking".
« Last Edit: May 22, 2020, 12:18:06 pm by Dragan »
« Reply #17 on: May 25, 2020, 08:33:21 pm »
Here is a quick macro with stacked blades...
There is a few more option to come but I need to check something with Itoo first (bug issues).
I will open a new topic about those to keep your topic `clean`
Best Regards
« Last Edit: May 25, 2020, 09:37:12 pm by Dragan »
