Author Topic: Parametric Window - X Evenly Problem  (Read 2633 times)
mavorte7
« on: November 17, 2022, 03:25:31 am »
Hi there  🙂
So, i've been studing RailClone in the past few weeks and trying to understand its concepts. So far, so good (I guess).
However, i'm trying to solve a problem with the "parametric window". As you guys can see, the "X Evenly" on the "top window" does not belong there.
I want to be able to stretch the rectangle on the Y Axis and let the "X Evenly" only in the space between the "bottom" and the "Y Evenly".
I was thinking that the solution might be related with some arithmetic expression connected to the "YSplineCoords", but from here, i don't know how to proceed.
Please, would you guys help me out?
Thanks in advance.
« Last Edit: November 17, 2022, 11:39:33 am by Paul Roberts »
Re: Parametric Window - X Evenly Problem
« Reply #1 on: November 17, 2022, 11:40:54 am »
HI,
Please see the attached. You pretty much had it all correct, I've just added the top window segments to your existing Sequence operators and tweaked the orders a bit.
I hope that helps,
mavorte7
« Reply #2 on: November 17, 2022, 01:07:21 pm »
Thank you very, very much, Paul  :)
Best regards.
