Author Topic: Translation during Clipping Area Expand  (Read 2531 times)
« on: April 16, 2019, 05:25:48 pm »
Just a quick question. What we can do about unwanted Translation during Clipping Area Expand?
Best Regards.
Re: Translation during Clipping Area Expand
« Reply #1 on: April 16, 2019, 05:37:39 pm »
1. Remove spline wire from Clipping Area.
2. Uncheck Extend X/Y Size to Area
3. Set Your own custom X Size and Y size to cover Your needed area and adjust RailClone Object location in the viewport:
4. Then plug in Spline back again to Clipping area.
Hope this helps.
« Reply #2 on: April 16, 2019, 07:01:29 pm »
Yes, that will work, although I have some multiple closed splines + surface included, so Expand was the simplest solution.
Some anchor point or start from the First vertex will be nice.
For some floor distribution translation could go unnoticeable but even then precise fixed start point would be nice.
Thank you.
