Author Topic: tile creation  (Read 2781 times)
OD7798
tile creation
« on: May 21, 2021, 05:06:49 pm »
http://joxi.ru/BA0NpzOHp5pplm
http://joxi.ru/VrwNqOnH4144XA
is there a way to make a similar tile layout in an easier way? and that it would automatically change depending on the size of the tile?
Re: tile creation
« Reply #1 on: May 21, 2021, 09:19:39 pm »
The style setup is based on one X translation driven by SegmentYcounter and the Expand parameter. I`m not sure how it will work on complex Spline with a lot of corners. So far it works fine.
I have exposed some parameters for you.
You can override the original segment size with Length1, Length2, Width parameters.
Use X/Y Offset to tweak the start position of the pattern.
Increase Expand parameter if there are gaps around the spline.
Hope this will help.
« Last Edit: May 23, 2021, 10:05:41 am by Dragan »
OD7798
Re: tile creation
« Reply #2 on: June 02, 2021, 02:13:14 pm »
thanks!
where i can read more about your method in  detail ... in the help I did not find anything similar ...
Re: tile creation
« Reply #3 on: June 02, 2021, 02:53:07 pm »
Well, You can`t find this particular method in the help document. This is just understanding RC+some math, but it is pretty simple.
You want to shift each row by the half size of the one `smaller brick.
I`m using two separate bricks with exported X Size for calculations and then Compose them into one `group`. Then with the transform operator just translate it for the half size of the second brick.
At one point you will get to the repeating pattern (distance) and that is the `K` value.
Second, I used this `K` with mod(####,k) formula to reset the `X Fixed Transform` value otherwise I will get a linear transform.
If I found time I`ll try to make a video clip for you to make it easier to understand. Right now I`m in the middle of a few parallel projects and there is no time.  :-\
« Last Edit: June 02, 2021, 03:14:45 pm by Dragan »
OD7798
Re: tile creation
« Reply #4 on: June 03, 2021, 09:01:54 pm »
thank you so much ...
