Author Topic: Parquet Chevron not working  (Read 3571 times)
II3700
« on: October 06, 2015, 03:20:23 pm »
I'm trying to apply the parquet chevron pattern to a spline area but when i do so the spacing of all floorboards seems to be completely off.  I've attached some screen grabs of the process.  I can get close to what it should be by tweaking but still doesn't seem to work.
THanks
Re: Parquet Chevron not working
« Reply #1 on: October 06, 2015, 03:27:25 pm »
It looks as though RailClone's adaptive display mode has activated. This happens when the face count for the objects exceeds an adjustable  threshold. The original geometry is replaced by boxes in the viewports to ensure that they remain fast and responsive. This is purely a viewport effect though, and the style should still render correctly.
You can deactivate this by changing the Viewport mode to Mesh using the settings found in the Display rollout. But for  large areas with many millions of polygons you may get some slow down. More information about this can be found in our online documentation here.
Many thanks,
II3700
« Reply #2 on: October 06, 2015, 03:34:11 pm »
Hi Paul,
Thanks, Problem solved
Cheers
