Author Topic: parquet floor tutorial  (Read 2704 times)
grue
« on: September 30, 2020, 08:36:52 pm »
https://player.vimeo.com/video/78717092
hello. i followed this tutorial and it worked great. however the planks are running horizontally. i would like my planks to run vertically.  when i go into the node for "full length" and "half length" planks, and change the rotation via the transform tab (3rd tab on right), it gets pretty sad.
i can change increment at y (from x) in the sequence, i can change the x counter / y counter in the segment section of the conditional... now it works from the point of view, it does fill the entire shape with planks, but they are not offset as they are offset horizontally in the horizontal version.
there's something missing me thinks :)
thanks.
Re: parquet floor tutorial
« Reply #1 on: September 30, 2020, 08:46:12 pm »
Use Z Rotation and Expand in the General tab.
grue
« Reply #2 on: September 30, 2020, 08:47:45 pm »
ha!  in the 2s1 array, that's where i can set the rotation of the whole thing instead of setting on each node(each plank). sweeet!
edit: thanks!
