Author Topic: pattern continuity question  (Read 2503 times)
Mattias
« on: October 04, 2019, 12:20:13 pm »
Is it possible to turn off the pattern alignment to the bottom left corner of a spline area (see image) so the pattern stays aligned across multiple spline areas.
kind regards,
Mattias
Mattias
Re: pattern continuity question
« Reply #1 on: October 04, 2019, 12:44:31 pm »
Managed to do it by using forestpack (grid distribution). I`m still curious if this is possible with railclone.
Kind regards,
Mattias
« Reply #2 on: October 04, 2019, 01:00:28 pm »
Absolutely!
1. Unplug spline node.
2. Disable extended X/Y size to area
3. Enter manually Your dimensions in X and Y parameters
4. Adjust RC object position to Your liking
5. Rewire clipping area
Hope this helps
Mattias
« Reply #3 on: October 04, 2019, 01:06:11 pm »
cheers
